TCS for Yokomo yz10 91 Works?
slow_jun
Post by slow_jun »
Will this fit a yz10 91 Works?
― Confucius
crusaderlyf
Re: TCS for Yokomo yz10 91 Works?
Post by crusaderlyf »
Original works91 comes center shaft like 870C, if you want to use TCS slipper system on works91, you must find rear belt slipper disk and oneway front belt pulley,both are use 2mm belts,like WCS,so hard to find.
slow_jun
Post by slow_jun »
Thanks yunfei, but will this shaft accOmodate if i can get the pulley ,oneway etc ... The parts used to have a tcs,?i read on here before that a pulley from abothe yoke car is still availble and a diy AE slipper would be able to work.
Just cant find the link :-(
― Confucius
crusaderlyf
Sure can work if you can settle the pulley and belt problems.
Alex B
Has thanked: 23 times
Been thanked: 46 times
Post by Alex B »
You will need the centre pulley, a YR4 version may work the inner plate for the slipper and the outer plate and thrust bearing which I think you could use the original stealth parts. The inner slipper plate is hard to find.
:shock:
Return to “Yokomo Forum”
