associated gold
susko
associated gold
Post by susko »
This is my driver rc10. It is pretty modified and in the process of being transformed into an off-roading machine. I want to replace most of the plastic parts with aluminum. If I ever have some extra cash I plan to put in a brush-less system. The setup I have now is faster than it looks and it has reverse. I know that sounds funny because almost all new cars have reverse now. I purchased an aluminum arm set from atlas but could not get the arm mounts.
I know people are going to criticize me for drilling into the chassis, but I did this to have more space for a better battery. It also turns a hell of a lot better now. Image
BTW I have one new in box so I am not as worried about modding this one.
Ignore my other hobbies in the background
susko
Re: associated gold
Post by susko »
I got the arms in from atlas yesterday. Things seem to be going along smoothly.I found out I need a new pin for one of the suspension arms. Some how it got bent. I think I can get those at just any hobby store so it's no big deal. If not I can order a whole set online.
Items purchased so far:
Atlas Gold Anodized Arm Set $52.50
rc10gt Blue Anodized Aluminum Front Knuckle Hub $22.50
rc10gt Blue Anodized Aluminum Front C-HUB $19
rc10gt Blue Anodized Aluminum rear axle HUB $21
Aluminum steering assembly for rc10 b4 t4 $16
Lohas Hurricane Wheels $105
TOTAL SPENT SO FAR-------------------------------$236 WOW
What do you guys think about compatibility of this with the gold tub? http://www.ebay.com/itm/130438118151?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Also should I get these? http://www.ebay.com/itm/270844470042?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I will post more pics when things start coming together.
Has thanked: 3699 times
Been thanked: 1980 times
Re: associated gold
Talk about diving in head first! :D I love your avatar by the way. HD thru and thru! 8)
Re: associated gold
the uni's in that link will be too long. i also don't see the b4 steering bellcranks working out, either.
RC104ever
Re: associated gold
Post by RC104ever »
susko wrote: rc10gt Blue Anodized Aluminum Front Knuckle Hub $22.50
I always wondered if the RC10GT aluminum stuff would work on the gold tub. Does it fit without modification? Are there any other parts that will fit?
- Chris
Lots of cars...so many cars
susko
Re: associated gold
Post by susko »
so far the front knuckle hubs fit like a glove(without modification) but the other parts have not arrived quite yet so I cannot say for sure. They seem to cross over pretty well though. I have used the parts from my b3 and t3 on the gold pan and they fit well without modification. It really depends on which part you are talking about. some cross over but others have no chance of fitting.
There are no problems with the steering it works better than the original. It actually has a good turning radius now. I figured the axle wouldn't fit. I have never owned a b4 and it has been a while since I have seen one up close so it was hard to say whether it was the right size. It would be easier if they would just list some dimensions. Thanks for the info.
RC104ever
Re: associated gold
Post by RC104ever »
So in the pics above, those blue aluminum steering bellcranks are from a B4? Because if they are, I'm off to buy a set right now!!
- Chris
RC104ever
Re: associated gold
Post by RC104ever »
Oh and in case you decide to switch to a stealth setup (you should), read this:
http://www.rc10talk.com/viewtopic.php?f=38&t=22861
- Chris
susko
Re: associated gold
Post by susko »
Yes it is the bellcrank for the b4 t4. http://www.ebay.com/itm/ALUMINUM-ALLOY-STEERING-ASSEMBLY-KIT-Fits-RC10-B4-T4-/360390729850?pt=Radio_Control_Vehicles&hash=item53e8f6207a
If you are wanting to install it on the gold pan you must drill 4 holes in the chassis 2 for the servo and 2 to mount the steering. It is a little tricky getting it all in the correct position so it functions properly.
Performance is next on the list, for now I am just getting it put together. It drives fine how it is and I can't spend to much more money on it until later. I have many other projects that I am working on like my MGA and Kingdom Key, not to mention school. I might put some money into the diff as well as motor in the future.
I will post a video of the steering in action latter tonight.
pics will follow when I get some more parts in the mail
susko
Re: associated gold
Post by susko »
Sorry there will be no video until I find my elusive video camera. Until then here are some moar photos.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: associated gold
Post by klavy69 »
Definitely let us know how that steering setup works out for you once its up and running. That looks good and was lookin at them awhile back when I was gonna canibalize a b4 for my 'old is new' build.
susko
Re: associated gold
Post by susko »
Moar photo srry bad lighting
I ran the car and the steering is amazing! It is so much better than stock. I think I want some knobby tires for the front and some bigger shocks as well. I bought that truck tower for this reason, but I am still trying to figure out how to mount the body. any suggestions would be appreciated. I will be buying the rear tower to match tomorrow.
btw my engine caught on fire so i think i need a new brushless set up. it was arcing for some reason. I am also having some transmission problems so I am sourcing a bargain stealth.
susko
Re: associated gold
Post by susko »
I think the truck tower idea is out. fitment is just too much work
Mindwarp
Re: associated gold
Post by Mindwarp »
Dude!! You really need to resize those pics! :!:
flipwils11
Been thanked: 19 times
Re: associated gold
Post by flipwils11 »
When I started on this board I read, read, lurked and read. Then when I had build ideas I searched and read some more. Even after that I bought parts that would not fit my build and I had to backtrack and ask for help.
I would do the same if I were you, although I think it took guts to get that steering in there.
Did you check out my gold metal shelfer build? (see link below)
Users browsing this forum: No User AvatarAmazon [Bot] and 6 guests
