Cougar 2 works part number required
Could someone please let me know the part number for the Transmission housing on a Cougar 2 works as i believe this is different to a U178 Transmission housing for Topcat/Cougar.
Does anyone have an image of a parts list which includes the Works parts ?
Thank you
John
Thank you
John
4x Procat
2x Cougar
1x Cat XLS
2x Cougar
1x Cat XLS
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Cougar 2 works part number required
Checking in the instructions manual in front of me right now (lucky mejohn73 wrote:Could someone please let me know the part number for the Transmission housing on a Cougar 2 works as i believe this is different to a U178 Transmission housing for Topcat/Cougar.
Thank you
John
U1343M housing
1344N/O plates
HAve fun - superb car
Paul
Thank you Paul
It is a part i need but can't look for it if i don't have a part number.
Also does the Cougar 2 works use the same rear wishbones and hubs as the Bosscat Works ?
Are you able to scan your part list which contains the various works part numbers ?
Cheers
John
Cheers
John
4x Procat
2x Cougar
1x Cat XLS
2x Cougar
1x Cat XLS
Maybe these parts are still available
http://www.tamiyaclub.com/trades_model.asp?cid=100551
I've just put a magazine article on the Cougar 2 works conversion in the scans section, it might be useful to you
http://www.rc10talk.com/viewtopic.php?f=7&t=22586
Paul.
Paul.
- Lonestar
Sure - I'll try to put a scan tomorrow
Happy to help
Paul
Happy to help
Paul
A big thank you to Paul, Paul and Jeroen
Cheers
John
Cheers
John
4x Procat
2x Cougar
1x Cat XLS
2x Cougar
1x Cat XLS
- Lonestar
here we go
(for the record I initially made a pdf but then rc10talk refuses pdf's... and then the JPGs I made were too big... so off to an external storage solution it goes)
Have fun - one of the sweetest 2wd's ever - I was pretty hyped up when I got mine from a kind forum member
Paul
Paul
Fantastic Paul
Thank you
John
Thank you
John
4x Procat
2x Cougar
1x Cat XLS
2x Cougar
1x Cat XLS
- DerbyDan
- Been thanked: 19 times
Great scan! Thanks
I've never raced my 'Works' - but I wonder if having those vertical slots for the motor adjustment caused issues with pinions becoming un-meshed with the spur gear?
- 30 Replies
- 5498 Views
Last post by Momo5
- 1128 Views
Last post by RogueIV
- 590 Views
Last post by a01butal
- 1289 Views
- 1211 Views
Last post by surgetek
- 1521 Views
Last post by liquorboxracing
- 805 Views
Last post by adam lancia
- 704 Views
Last post by PBR Allstar
