Zx-r mk 2 part number help
Tamiyaterror
Post by Tamiyaterror »
Guys I'm desperatly seeking the part number for a zxr mk2 motor mount. I can only find the part number for the mk1
Can anybody help?
Thanks in advance
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Re: Zx-r mk 2 part number help
Post by terry.sc »
The motor plate is LA-62 Motor Plate Set.
The ZX-R Mk2 supplement is included at the end of the ZX-R manual on Retromodelisme
http://www.retromodelisme.com/manuel_page/52/lazer-zx-r-kyosho.html
Tamiyaterror
thanks terry, i also need the mk2 motor spacer which appears different to the mk1 also, i cant see the part number for this, any ideas on that?? i may be being blind!
isobarik
Been thanked: 10 times
Post by isobarik »
Tamiyaterror wrote:thanks terry, i also need the mk2 motor spacer which appears different to the mk1 also, i cant see the part number for this, any ideas on that?? i may be being blind!
between the motor and motor plate ???
mvh isobarik
Tamiyaterror
yes thats the bit, i need the motor plate and also the bit between the plate and motor, i need both parts. my zx-r is going nowhere without :cry:
terry.sc
Post by terry.sc »
The motor spacer is part number OT-73, motor cleaner set. It's from the Kyosho Optima. It's not needed to get it running as all it is used for is to space the motor away by 3mm,
Tamiyaterror
cheers terry, i did wonder what use it was, i still need the mount tho sadly, as when i was much younger i decided it would be a good idea to lengthen the motor screw holes in the mount, and totally ruined it. i was only 11 at the time! ill keep my eyes open, thanks for the help mate, i can now commence my hunt!!
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
Tamiyaterror wrote:cheers terry, i did wonder what use it was, i still need the mount tho sadly, as when i was much younger i decided it would be a good idea to lengthen the motor screw holes in the mount, and totally ruined it. i was only 11 at the time! ill keep my eyes open, thanks for the help mate, i can now commence my hunt!!
Should you not be able to find one, know Fibre Lyte and some other manufacturers make aftermarket plates...
Return to “Kyosho Forum”
