cougar 2 works part?
I know I am asking for a bit of a miracle but the only thing I am in need of to finish my c2 works car for our vintage race in feb. is the 2 part lexan gear cover. Anyone?!?!?!? PLEASE?
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Re: cougar 2 works part?
A guy here in Melbourne (Ant Howard) did a handful of repros for Bormac (Jason Millhouse) a while back.... but not sure if he's doing any more any time soon.... maybe a petition here would help. I know I could use one.... autoxvw, that's two.... anyone else????
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Ant did make the mold but good luck to anyone who thinks he'll get around to making any in the near future- LOL!
- vintage racer
Mine just went missing when I gave my car to a guy for a rebuild so Ill be needing one too.
- Bormac
Yep I'll put my hand up for this one- LOL. Not happy with one of my mates driving a car that looked as though it was ready to be retired I offered James my Schumacher rebuiding services to see if I could get this car up to scratch for the race track. I wish I had of taken before pics as the car was in dreadful shape. After getting it back to my workshop I stripped down 'EVERYTHING' then cleaned and inspected each individual part for wear. Whatever I found worn or broken i replaced ( Free Of Charge) and even spec'd up the car by replacing the bronze bushes I found in the steering levers with the correct bearings and spacers. The car was well used/raced and much of it was hanging on by a thread but after 2 days of solid work I ended up replacing the drive belt and pulleys,new spur gear with correct ratio for the stock motor,replaced most of the screws/nuts etc..polished the shock shafts,deep cleaned all the sealed bearings then relubed with 'INOX' for smoother operation, supplied reasonable used tyres both front and rear while stripping the worn rears and 'BLEACHING' the rims and discs to match a set of fronts I had which I was throwing onto the fronts to replace the original Cougar 1.9inch rims. The list goes on- I rewired the speedo, supplied another servo and an assortment of other bits and bobs. Needless to say after testing the car it is ultra smooth and look a treat better than what it used to.vintage racer wrote:Mine just went missing when I gave my car to a guy for a rebuild so Ill be needing one too.
James if you are reading this please give me a call. Ive been trying to call you but you arent answering- not sure why??
As for the gear cover- 'I FOUND IT!'. What a goose, I had it in with your old spares and must have overlooked it. Im sorry about the confusion.
The car is just about ready. I still need to get you those front shocks from Heavy. The ones on the front pictured i have borrowed temporarily from by Procat. Give me a call. Cheers-Jason.
Bormac,
I won an auction on ebay.co.uk for a works trans housing and side plates, 1 alum roller shaft a belt a GEAR COVER
(in decent shape) and also the alloy belt tension adjusters!!! I was very shocked when I saw them on ebay and bought them on the spot. should have them in a few days now. I am still working with jeroen and mrlexan on gettin some reproduced.
On racing-cars.com's forum there is another person looking for a c2 works gear cover. I would still like to have a new one as well. Mrlexan, are we any closer to gettin these repoped?
still in need. Anyone (mrlexan) have any idea where to get one or have one made?
- kenooze It’s my birthday!
I spoke with Jay, I'm able to provide an original NIP set, but this one will be destroy during the mold process.
So I'm not enthousiast...
Ouch!! Did not know that. I understand the concern on your part. I would be able to compensate you a bit if you decide to go ahead and sacrifice your OE cover.
- 2052 Views
Last post by DerbyDan
- 24 Replies
- 5564 Views
- 3302 Views
Last post by yorak
- 3553 Views
- 36 Replies
- 5987 Views
Last post by Bormac
- 3145 Views
Last post by Kedal
- 1423 Views
Last post by isobarik
- 1772 Views
Last post by moozo
