Replacing 6 gear with Stealth tranny
- Rizzo
G'day Guys
Tried doing a search, but couldn't find anything.
is there a how to on this Site on installing a stealth tranny to replace the standard 6 gear tranny?
All I know is that I need to drill my chassis to suit the stealth, other than that, is it just a direct swap? Is there any extra parts i need?
Any help would be most appreciatted
regards
Jak
regards
Jak
"Don't underestimate the power of a backhander. They F&^%ing hurt" SuperWog
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Replacing 6 gear with Stealth tranny
drill holes, bolt in stealth. make sure you have a stealth trans brace, too.
Scr8p is right on.... and I am doing the same thing, and in my travels I did find this that will make things easier to drill the holes for the stealth.
Thanks again to ROH73 for doing this, keeping it, and then posting it up. Very helpful stuff and much appreciated.ROH73 wrote:I measured/documented an entire chassis a couple of years ago on an optical comparator. Here's the rear section: http://www.tunneltwo.com/rc/rc10_chassis_rear_hole_pattern.pdf
Just print 1:1 and drill to your heart's content.![]()
Regards,
Robert
- GJW
you weren't happy with the six gear at castle hill were you jak, did you buy some new radio gear yet?
gary
gary
- Rizzo
Hi Gaz
I don't think it was my radio gear, I think it was more like the 20 year old steering servo in the car...........
same for my Wild One & Sand Rover, they still have the 20+ year old steering servo's
I would prefer my RC10 to also "sound" like everyone elses, mine is noisier with the 6 gear as apposed to all the stealth Rc10's
jak
jak
I did the same swap with my Cadi 6 gear buggy. But, I had a newer "B" chassis to use as a demplete. I just laid them bottom to bottom and traced the holes for the stealth onto the "A" chassis then center punched, drilled and counter sunk. Worked like a charm. But i guess this only works if you have the two different chassis.
get a piece of cardboard and make a template, testfit the cardboard, then use it to drill the holes. This way you dont mess up the car, and if you make a mistake, well its only cardboard
- 1322 Views
Last post by binjaloo
- 1762 Views
Last post by superfly
- 1734 Views
Last post by knucklebuster
- 922 Views
Last post by JK Racing
- 395 Views
- 1288 Views
Last post by badhoopty
- 21 Replies
- 1967 Views
- 896 Views
Last post by henry
Users browsing this forum: Ahrefs [Bot] and 5 guests
