What is the gear ratio on the 6 gear tranny?
General info, Q&A.
tbfoto
Post by tbfoto »
Just rebuilt my 6 gear tranny. I have a 54 tooth spur gear (64 pitch I think it is). What size pinion should I use for a stock motor? Also does anyone know what that Tranny gear ratio is?
tbfoto
aconsola
Re: What is the gear ratio on the 6 gear tranny?
Post by aconsola »
The 54T spur is most likely a 32pitch.
I was just wondering what the gearbox ratio is myself and was going to look it up.
To add to you question, How would a modern stock motor vs a vintage stocker change the starting point for gearing?
tbfoto
Post by tbfoto »
aconsola wrote: How would a modern stock motor vs a vintage stocker change the starting point for gearing?
Do you think it would change at all? I realize that modern day motors may be better made but I'm not so sure their output would be much better. Some of those older motors were pretty good!
tbfoto
Has thanked: 33 times
Been thanked: 1213 times
i was told many years ago that it's 1.83. but, i've also seen it labeled a 1.85, and even 1.87. so, take your pick. :wink:
JK Racing
Has thanked: 130 times
Been thanked: 242 times
Post by JK Racing »
I have always used 1.85 when figuring gear ratios out.
Your gearing is going to depend on the track your racing at, or if bashing, how much speed/runtime/heat your want or are getting.
54 @ 32 pitch = 81 @ 48 pitch (most all modern offroad cars are 48 pitch)
For stock racing (in my modern car), I run 78/20 * 2.6 = 10.14, for larger tracks, and down to an 18 on smaller tracks ( 11.27 final )
Even running a 10T pinion, with 54 spur, your looking at 9.99 (54/10*1.85).
To figure final ratio out...
Spur/Pinion*Tranny ratio = final drive.
Dont forget to take into account rear tire size, smaller tires can take a lower final drive number.
Hope that helps some.
