Stealth Tranny parts
henry
Post by henry »
Hello all. I was wondering if anyone knew of any online retailers that still stock parts for the 2.25 stealth tranny? I looked at another post on this forum that had some links to Tower Hobbies and I searched tower but to no avail.
If there's already been another thread posted a link would be greatly appreciated as well.
Thank you.
soniccj5
Re: Stealth Tranny parts
Post by soniccj5 »
Here is a link to a bunch of Stealth parts on tower
http://www3.towerhobbies.com/cgi-bin/wti0005p?&I=ASCC4660&P=OW
Here is a list I was putting together. I deiced to buy used, after seeing how much a new one would cost.
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6580&search=Go : Diff gear 2:38
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6581&search=Go : Diff balls 12.00
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6578&search=Go : od HUB lEFT 7.19
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6577&search=Go :OD hub left 7.19
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6582&search=Go : Spring 1.50
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2867&P=7 :diff thrust washer and bolt 2.89
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2868&P=V :Thrust Bearings 2.00
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6579&search=Go :Diff Drive rings 1.50
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6572&search=Go :Drive Shaft Roll Pin 1.00
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6571&search=Go :Drive Shaft Gear 8.59
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6570&search=Go :Idler Gear and Shaft 3.39
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6570&search=Go :SCrew 4-40x1" (6) 2.00
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=6585&search=Go :Clutch Disk 2.89
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6584&search=Go :Outer Slipper 7.19
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6583&search=Go :Inner Slipper 7.19
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6587&search=Go :Torque Control Spring & Locknut 1.50
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6568&search=Go :Stealth Spur Gear Screws 1.50
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=6693&search=Go :Spur 81T 3.89
You can also go through the parts manual to find the part number then search on tower.
ED
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Post by LowClassCC »
henry
Post by henry »
Thanks guys! :D
