10t diff prob
- Regular Member
10t diff prob
So, I have a 10t and the diff keeps loosening up. I took the trans apart and replaced the diff balls and the little diff rings. I put everything back togather and for some reason the diff keeps coming loose. Does anyone have any ideas?
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: 10t diff prob
You installed it backwards or the T nut is bad- the 5/64 adjuster hex has to be on the same side as the input shaft, otherwise it loosens with every burst of the throttle.
- Regular Member
Re: 10t diff prob
I did have it in backwards but I swapped it around a few days ago and I'm still having the problem. I'll try and replace the t nut next.
Re: 10t diff prob
Check the thrust balls and the 2 washers, if anything is missing it will not have enough clamping force to hold the adjustment. You may have grooved the rings a bunch if it was a hot motor and it was slipping a bunch.
- Regular Member
Re: 10t diff prob
Hey thanks. I'm gonna replace the thrust bolt, washers and balls and the t nut and that should solve my problem.
My 10t has been sitting for about that last 20 years and I decided to throw a castle short course system in it nad I prob over heated something.
- 24 Replies
- 2028 Views
Last post by Tadracket
- 699 Views
Last post by Bormac
- 1082 Views
Last post by greene-r74
- 2850 Views
Last post by coxbros1
- 1776 Views
Last post by CamplinP
- 47 Replies
- 8826 Views
Last post by KidAgain
- 1062 Views
Last post by Phin
- 2687 Views
Last post by Chewbacca
Users browsing this forum: Google Adsense [Bot],
Mojeek [Bot] and 3 guests
