6 gear help - diff pinion stuck to diff tube
Is there some trick to get the diff gear off the diff tube. I have a bushing in there I'd like to replace with a bearing, but I can't seem to get the thing apart. Anyone have suggestions?
- CamplinP
Re: 6 gear help - diff pinion stuck to diff tube
This can be tough sometimes. First I would try some break free or some type of penetrating lubricant. A side to side motion can loosen it up. Be careful with tools as both of these parts are soft metal. I have also used heat to get them apart. You do not need to get it very warm. Work quickly before the whole part reaches the same temp. The outside part will expand before the inner piece and they shlould release.
I gently banged it off. Since the gear doesn't go fully on the tube you can get something to fit inside the gear against te edge of the tube and tap it out. I just did mine and I may have used the fat part of the diff shaft to do it. Even though it really felt stuck on, mine came off fairly easy. Remember that when you put it back together that the diff tube does not come through even with the gear. It is recessed.
- Has thanked: 36 times
- Been thanked: 1318 times
- transamman908
- Been thanked: 5 times
- Attachments
- welder-torch-goggles_~e00004532.jpg (21.07 KiB) Viewed 1068 times
what? that's how i do it. if it didn't work with out f'n stuff up, i wouldn't suggest it.
Spray a considerable amount of WD-40 onto the parts and let it sit for a minute or two. With a teethless long nose plier on the gear, give the plier a gentle tap with a hammer. It should be easy. At times, the dried grease or dirt jammed the whole thing.
My collections:
Nikko Brat, Nikko Dictator II, Nikko Thunder Eagle, Kyosho Pure Ten Nitro, Associated RC10, Associated RC10T, Associated RC10 Graphite, Associated B4, Tamiya Tamtech 1/24 Porsche 962C, Tamiya Striker, Tamiya TRF 501X WCE.
get a big pair of wire cutters, the cutting jaws are angled, so you put the jaws open end facing the gear and a little squeeze and the gear pops right off. I know this is an old thread. But still a good tip.
- 496 Views
Last post by FordPSD
- 47 Replies
- 8814 Views
Last post by KidAgain
- 2850 Views
Last post by coxbros1
- 2685 Views
Last post by Chewbacca
- 926 Views
- 2125 Views
Last post by rccars4sal
- 1772 Views
Last post by CamplinP
- 500 Views
Last post by joe sumasky
