stealth trans prob
- Banned Member
stealth trans prob
stealth trans in a rc10T. truck rolls at slow throttle, but when you pull trigger all the , the spur gear just spins and the truck is barely moving. ive tightened the nut on the spur ,still doesnt do any thing. usind 12 tooth pinion and a 52 tooth spur again.first time running this truck, any ideas on how to fix this?
- Has thanked: 36 times
- Been thanked: 1318 times
- Banned Member
Re: stealth trans prob
how are you supposed to set it? it was already in the truck, i just put the motor and electronics in to test it.its free of dirt and debris. i swapped out the trans for another spare i had, but still , need to figure out whats wrong with this one because it will go along with a car i sell or trade.
- Banned Member
so theres belt driven ones and and gear driven ones. im learning something everytime i get on here.
should be a quick rebuild i hope. looks like a simple set up
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Be sure that your diff is tighten properly and follow each and every instruction from the Stealth manual. Be sure that the diff nut is on the left side so that you tighten the diff on the right side (motor plate side) otherwise each time you will pull the trigger your diff will unscrew...
Come and visit the stable
- Been thanked: 81 times
Sounds like the diff bolt has loosened up . Or it may have been overtightened and has broke the plastic nut holder the keys into the outdrive. I would pull the trans take it apart and check the diff.
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
The most important thing with diff rebuilds is to make sure there is little to no slip. If the diff is slipping it will generate heat and ultimately melt your diff centre which is made of plastic. I'd rather run a diff thats a little more tighter than too loose.
- 1927 Views
Last post by badhoopty
- 1285 Views
Last post by longboardnj
- 115 Replies
- 15087 Views
Last post by woodall01
- 916 Views
Last post by MarkyDents
- 1580 Views
Last post by tiger1
- 1025 Views
Last post by klavy69
- 2397 Views
Last post by lmw94002
- 1500 Views
Last post by burnsmonkey
