Graphite
- Johnboy72
Graphite
Ok, so thinking of doing some playing around and would like to get material for shock towers and little stuff like that. Also, I'm considering building a sprint car so might need to find some material for a chassis plate. I've seen sheets in the past on Ebay. But I don't know what thickness and what's better for what. I had seen some colored graphite sheets at one time too. Any info would be cool. Was gonna use the search button but my 1yr old thinks he has to sit in my lap every time I pull out the laptop. AGH.
- Has thanked: 10 times
- Been thanked: 454 times
Re: Graphite
it is available in alot of places, just depends on how much you want to pay. you will mostly find the 3k weave, which is the large woven type look, but you can get other types as well as texalium which is aluminized carbon fiber and has different colors.
you should shoot for mostly 3mm or 1/8" for chassis and shock towers at a minimum. I've seen some towers on ebay that are 2mm, but I really think that is too thin.
most chassis have a kickup built in, but you will be hard pressed to find raw stock to make your own. one option is to use a flat plate and use something like this as a front bulkhead:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJH19&P=7
oh, with a 1yr old especially, be very careful with the dust that you generate when cutting carbon. I've seen all sorts of conflicting reports that say it's very bad for you(like asbestos), or that it's not bad, no-one really seems to have a solid factual concensus at this point, but I would error on the side of caution. use water when cutting or do it outdoors with a mask on, etc etc and try and use something that does not throw dust out (like dremel etc.) unless you control the dust somehow.
- mrlexan
- Been thanked: 10 times
Re: Graphite
I don't think it's limited to just 1 year olds..... yourself included. Anything other than air or water vapor (anything un-natural) is bad for your lungs.jwscab wrote:oh, with a 1yr old especially, be very careful with the dust that you generate when cutting carbon. I've seen all sorts of conflicting reports that say it's very bad for you(like asbestos), or that it's not bad, no-one really seems to have a solid factual concensus at this point, but I would error on the side of caution. use water when cutting or do it outdoors with a mask on, etc etc and try and use something that does not throw dust out (like dremel etc.) unless you control the dust somehow.
www.gojammedia.com
www.gojammedia.com
Re: Graphite
yes, of course....I just mean to make sure your 1yr old isn't out checking out what daddy is doing, with no protection, unbeknownst to daddy....
it's like the dog watching you weld with no eye protection, while you are busy and don't know he's there......sometimes it just happens.....
- Johnboy72
Re: Graphite
Oh, I understand what your all saying. I do the grinding and such down in the basement as the wifey doesn't like me using the dremel upstairs. So looks like 3mm then. I'll check out ebay. As far as the Sprintcar, I'm looking to build up the chassis like my KRP cars but using modern suspension and stealth transmission. The front kickup will be incorporated into the frame or I'll use something similiar to what's on my Cobra Nemesis.
- EvolutionRevolution
- Has thanked: 20 times
- Been thanked: 36 times
Re: Graphite
If possible, try to work under water or under a stream of water. Graphite/carbon dust is really bad for you (like, cancer bad). ![Sad :(](./images/smilies/icon_sad.gif)
Re: Graphite
Carbon cuts well under water cooled conditions, any tile that I cut blanks I use a diamond wet saw and a tile cutting table.
But you body is composed of carbon- and the only real symptom of carbon dust intake is black lung which is a serious issue, but Fiberglass is way way way scarier to inhale as it is a 100% foreign particulate.
- 932 Views
Last post by CON2
- 2008 Views
Last post by lexus-5
- 958 Views
Last post by slim_chance
- 1289 Views
- 1112 Views
- 59 Replies
- 3541 Views
Last post by Frankentruck
- 20 Replies
- 2325 Views
Last post by thomas1
- 760 Views
Last post by Dr. Robotnik
Users browsing this forum: DotNetDotCom.org [Bot] and 20 guests
