Pics aren't the best and I realized after taking them the whole car needs a good cleaning. Maybe I'll pull it apart when im laid up next month. Hope you like it!
jwscab wrote:maybe that trans/bulkhead support?
I would put some nice big flat washers behind the heads of the motor screws, to prevent mangling up the carbon fiber; this way the screw head doesn't grind into it.
LowClassCC wrote:bass ackwards stealth tranny brace.
front upper spring collars are not in the same position as the rear.
no servo to steering tie rod.
side to side line line on the chassis under the battery.
and your e-clips are not all facing the same direction!
good looking car. didn't somebody make a carbon "shelf bracket" to mount an electric speed controller on the rear tower?
Thats actually a fiber sticking up off the surface. There are a few of them on the chassis and I was going to trim them off when I built it but then I thought they are only there once. When new!LowClassCC wrote:whelp unless you are talking about the little spot that looks like it could be a chip of a crack at the hole that intersects that side to side line that runs under the battery you got me stumped.
scr8p wrote:the only thing i see is that you have 3 left side shock collars, and one right. other than that, i don't see any flaws. nice car dude.
Users browsing this forum: Google [Bot] and 4 guests
