New to me graphite
thomas1
New to me graphite
Post by thomas1 »
A friend of mine gave me a box of RC stuff for my 5yo son to play with. Mostly a bunch of cheap junk that'll only be good for him to smash in the sandbox. At the bottom of the box was this...
What is the best way for me to get this thing going on the cheap? No controller was included, so I'll need that and batteries at the very least. What are the 2 wires (red+green) coming off the speed controller?
DaveM
Has thanked: 727 times
Been thanked: 26 times
Re: New to me graphite
Post by DaveM »
Hi,
Is the speed control a Novak T-4, if so here is the manual,
http://teamnovak.com/file_download/1299712885T1_T4_Instr.pdf
Step 4, hook up instructions.
Cheers, Dave. :)
RC10th
Has thanked: 55 times
Been thanked: 1587 times
Post by RC10th »
Trinity slot machine, my first motor..
DaveM
Post by DaveM »
Looks like,
ROAR legal 27 turn, 24 degree "stock" racing motor.
thomas1
Post by thomas1 »
DaveM wrote:Hi,
Cheers, Dave. :)
It is, indeed. Thank you, sir.
thomas1
Post by thomas1 »
RC10th wrote:Trinity slot machine, my first motor..
DaveM wrote:Looks like,
mikea96
Has thanked: 672 times
Been thanked: 882 times
Post by mikea96 »
Nice RC10 graphite you got there!
Has thanked: 37 times
Been thanked: 1352 times
I believe the 350 was actually an 18 double.
I wonder how well it worked wired on the same side? :mrgreen:
RC10th
Post by RC10th »
Wow, similar label.....
thomas1
Post by thomas1 »
It's only going to be used for thrashing around the house, is anything obsolete or can I just get some batteries and a controller and run what I have?
Has thanked: 3739 times
Been thanked: 1988 times
Nice find. Assuming the electronics work, you should be able to clean it up and run it with a new radio and battery. As alluded to above, make sure the +/- wires are put back on accordingly.
thomas1
Post by thomas1 »
I think they just got a little carried away when the were soldering on the resistors. Which is weird because the lead sharing the tab with the green wire is not soldered at all and just wrapped through the hole in the tab. I believe the power wires are soldered to the proper tabs, correct? How do you guys like that super secure terminal connection?
Oh ok, you're good. The other pic made it look like the wires were on the same side.
DaveM
Post by DaveM »
Part of the fun is going through the wiring and sorting it out.
You have the Novak T-4 manual, good luck.
Heat up your soldering iron and into it.
Cheers, Dave. :)
Users browsing this forum: No User AvatarAhrefs [Bot] and 6 guests
