2.4GHz antenna length
esaresky75
Post by esaresky75 »
Purchased an additional Associated XP TRS401 receiver from ebay, antenna is cut to about half original length. Is that a no-no with these like the older 75MHz stuff?
Burn more coal - UnderGroundMiners.com
Has thanked: 3699 times
Been thanked: 1980 times
Re: 2.4GHz antenna length
It should be fine, but I would definitely do a range test before you drive it too far.
esaresky75
Let me ask this, seller claims it came that way from a sealed in box SC18. I say he cut it, you can see the marks from side cutters and the end isn't stripped back like the other two I purchased from two others sellers. Anyone here own a SC18 with the XP TRS401? Is the length 6-1/2" or 12".
Midwest_Mudder
Post by Midwest_Mudder »
I don't own that particular model, but the 3 2.4GHz receivers i have all have about a 5-8 inch long antenna. Came that way straight from the box. But like suggested, do a range test, or have a very trusted Fail Safe if its a nitro.
Raised on cornfields.... Killing on Paintball fields... Nebraska Baller Through and Through
