Looking for ideas for an antenna mount
call-911
Post by call-911 »
Looking for ideas for a nice and simple antenna mount for a modern RC10 build. I'm thinking something in aluminum anodized black or black delrin would be nice. I guess I could always dye a stock RC10 mount too, but it wouldn't be as cool. 8)
Keith C
Re: Looking for ideas for an antenna mount
http://www.teamirsrc.com/antennamount.html
they have it in natural, blue, and black. a little expensive, but.....................
Eau Rouge
Post by Eau Rouge »
Spektrum radio, dude... cut antenna to 3.6" and pigtail around a small screwdriver. The best antenna is NO antenna. ;)
And maybe it's just me, but unless it's a DSM radio, sticking an antenna through a piece of aluminum sounds like a bad idea. :?
aeiou
Post by aeiou »
This is the one I used on my modernized RC10 build. Simple and black:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNTD2&P=7
call-911
Post by call-911 »
Eau Rouge wrote:Spektrum radio, dude... cut antenna to 3.6" and pigtail around a small screwdriver. The best antenna is NO antenna. ;)
I thought that the antenna needed to be vertical for a short period though. I'll be putting a spektrum receiver in it, but a little antenna would need to be braced a little if it was pigtailed wouldn't it? I would think with the concept of metal fatigue that a pigtailed antenna flopping around inside the car would eventually cause the thin wire inside to break.
I like that custom works antenna. It looks like it works similar to the Losi mount with the collar. Maybe I'll do that.
Keith C
mikedealer
Post by mikedealer »
MelvinsArmy
Been thanked: 11 times
Post by MelvinsArmy »
Eau Rouge wrote: And maybe it's just me, but unless it's a DSM radio, sticking an antenna through a piece of aluminum sounds like a bad idea. :?
Exactly. I never understood why they even made aluminum antenna mounts.
"It looks cool, but it can be a handful to drive" :lol:
badhoopty
Has thanked: 183 times
Been thanked: 157 times
Post by badhoopty »
for crawlers i often coil the antenna around some fuel tubing, then put heat shrink over it. then you just use the i.d. of the tubing for a screw.
Eau Rouge
Post by Eau Rouge »
call-911 wrote:I thought that the antenna needed to be vertical for a short period though. I'll be putting a spektrum receiver in it, but a little antenna would need to be braced a little if it was pigtailed wouldn't it? I would think with the concept of metal fatigue that a pigtailed antenna flopping around inside the car would eventually cause the thin wire inside to break.
Nope, I ran a pigtail coiled 3.6" antenna on a 1/12th scale car for 2 seasons. It doesn't move at all, as it's only about 1" long when coiled up and sticking straight up off of the receiver.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarAmazon [Bot], No User AvatarGoogle [Bot] and 4 guests
