Compatible rear arm mounts?
What rear arm mounts are compatible with the 10T? The only ones that I can find are the gold aluminum ones on eBay that I think a forum member makes. I think my truck had two left sides on it.
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 470 times
Re: Compatible rear arm mounts?
AE made a few but the 1.5 deg is standard. RPM and Andy's also made them but both are out of production as well- Try an ebay search for rc10 parts, they are the same between buggies and trucks just not the B2/B3/B4
hey can i use RPM RC10t arms with, RC10 arm mounts and hub/axle carriers and steering knuckles?Charlie don't surf wrote:AE made a few but the 1.5 deg is standard. RPM and Andy's also made them but both are out of production as well- Try an ebay search for rc10 parts, they are the same between buggies and trucks just not the B2/B3/B4
with age comes a cage
- slotcarrod
- Been thanked: 45 times
Not on the front, you have to use a truck (10T) nose plate and bulkhead. The rear will fit fine!drillNink wrote:
Rod Littau
- Toasted Coastie
When dealing with the gold pan style AE cars, you're pretty limited with the rear suspension mounts. eBay, and maybe, if you are lucky, some local shops might have what you are looking for. You can't mix and match with that particular part like you can with others.
- 1846 Views
Last post by cowsrneat2002
- 1176 Views
Last post by longboardnj
- 1756 Views
Last post by templeofspeed
- 1241 Views
Last post by ELF-BMX
- 509 Views
- 1349 Views
Last post by DaveM
- 1076 Views
Last post by slow_jun
- 1533 Views
Last post by askbob
Users browsing this forum: Google Adsense [Bot] and 1 guest
