stripped hole in 10T nose
The main screw for the steering bell crank has a stripped hole in the 10T nose. Any suggestions to fix it? I thought about peening it over a touch on the threads and then using my special locktite.
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
Re: stripped hole in 10T nose
what is SWB/LWB... i had to google this, i assume you mean wheel base?Charlie don't surf wrote:Use the SWB/LWB holes that are not srtipped-
It is set up as the long now, i can move it but preferred to keep it there it is.
If there is no decent fix then i will.
Do i cut the tubes too then, i see there was not an extra hole in the side for that WB change
you can try using a center punch and punching around the hole, maybe....5 times or so? then use locktite.
another option would be to use a small piece of aluminum approx. the same thickness as the chassis, like a thin jamnut between the two screws(make it fit between both screws, and you don't have to hold it to tighten the screws. It will make the bellcranks sit slightly higher, but it may work.
jwscab wrote:you can try using a center punch and punching around the hole, maybe....5 times or so? then use locktite.
I like this idea!
Charlie don't surf wrote:jwscab wrote:you can try using a center punch and punching around the hole, maybe....5 times or so? then use locktite.
I like this idea!
I did this and it worked. All is good.
thanks
- 1325 Views
Last post by treehugger
- 935 Views
- 1064 Views
Last post by SluggoV2
- 22 Replies
- 4572 Views
Last post by THE H.P FREAK
- 1897 Views
Last post by N2Deep
- 1170 Views
Last post by bscotti
- 1517 Views
Last post by suby56
- 26 Replies
- 3201 Views
Last post by juicedcoupe
