Pinion hex screw stripped
Hello, any advice on how to take the pinion off where the hex screw is stripped?
Re: Pinion hex screw stripped
Get a pinion puller pull it off ,or sometimes a lil flat head will do it
- wait a minute
lebowski770 wrote:Thanks guys, got it with some channel locks and a flat head
You can do that but you have to be careful you don't damage the armature.
wait a minute
pinion set screw is probably too small, but I used a square drive screwdriver bit and dremeled it down a bit and was able to use it to remove a set screw that holds the hex pin from a 1/8 scale axle...that and I used some Kroil oil...best penetrating oil I've every used.
another thing that I have done is used a donor allen key and applied a very small amount of JB weld to it and was able to unscrew after it dried...but it wasn't a set screw...so I'm not sure if this will work for you or not.
- 1897 Views
Last post by N2Deep
- 21 Replies
- 3202 Views
Last post by sundevil67
- 1316 Views
Last post by lmw94002
- 935 Views
- 1170 Views
Last post by bscotti
- 1517 Views
Last post by suby56
- 719 Views
Last post by muck
- 22 Replies
- 4573 Views
Last post by THE H.P FREAK
