Need length of Idler gear shaft in Retrofit Transmission
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
Morning guys,
can someone measure the length of the idler gear shaft in a retrofit transmission for me? It's 1/8" diameter right? Thanks!
Adam
HWS_Losi
Re: Need length of Idler gear shaft in Retrofit Transmission
Post by HWS_Losi »
You're in luck, I have my XX retrofit tranny apart due to rebuilding my Jrx Pro SE. Sadly the case has some damage, but I can measure the idler shaft for you!
The diameter measures 0.1240 on my caliper (so yes, 1/8"); and the length measures as 0.7465, I'd call that 3/4" long.
edit: this is for a 2.19 case. I assume both ratios are the same, but just in case....
bearrickster
Post by bearrickster »
they both take the same shaft.
LOSI RULES!!
Bearrickster's Rides
adam lancia
That's great, thanks HWS and Rick!
bearrickster
do you need one?
LOSI RULES!!
adam lancia
Yeah, but I've got a couple of old allen drivers with 1/8" shanks, I'm just going to give one a trim for now. It's only to mock it up at the moment but if I do a good enough job, I'll just leave itlike it is.
bearrickster
I have a used one you can have. pm me your adde I will mail it out tomorrow
LOSI RULES!!
adam lancia
Hey Rick,
I just got home to my parents place in Toronto and I found a few kicking around in a prts box so I'm set. I was at home in Germany at the time and thought I'd have time to tinker around with it....but then ran out of time :roll: Thanks anyhow!
Adam
Return to “Losi Forum”
