Screw size for idler gear in 6 gear???
General info, Q&A.
justinspeed79
Post by justinspeed79 »
Does anyone know the hex size for the tiny screws that hold the bushing in the idler gear on the six gear tranny? None of the sizes I have seem to fit it, and I want to put bearings in it.
i believe they're .050, like a pinion set screw. i don't have any laying around to be positive on that, though.
teshreve
Has thanked: 31 times
Been thanked: 27 times
Post by teshreve »
They are smaller than .050.
That is all I know.
Bought my first RC10 in 1989
justinspeed79
Nope, not .050. I tried about 4 different .050's, no go. This has got me stumped, I thought I owned every hex size known to man! :?
Thanks anyway Scr8p. :)
ya, i was wrong on that. sorry. :oops:
i found a couple of the correct allen wrenches. if ya need one, pm me your address.
teshreve
Post by teshreve »
My calipers tell me the size is .0345 ish.
Pretty damn small in any case.
Ron Jeremy wrote:My calipers tell me the size is .0345 ish.
i think your right. i did some looking around. the smallest three hexes i can find are .028, .035, and .050.
justinspeed79
So looks like .035 then. I'm going to take on of them up to the hardware store with me tomorrow and see if I can score one, probably have to buy a whole set. :roll:
Thanks for the offer Scr8p, I may take you up on it if I can't find one tomorrow.
Thanks for the measurement Ron!
:D
Whiskers
Post by Whiskers »
:lol: :lol: :lol: Now I know what those little screws and the little allen wrench were for. I found them and they were just the right size to fix the clip on my knife. :lol:
superfly
Post by superfly »
just buy a new set of idlers from tower and you'll get the little allen key with a set of new screws that comes with the new gears. The heads of the screws strip very easily...I've had to notch a few with a dremel to remove...not hard with a cutting wheel but a pain none the less...
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
superfly wrote:The heads of the screws strip very easily...I've had to notch a few with a dremel to remove...not hard with a cutting wheel but a pain none the less...
I have used fine valve grinding paste on the tip of the wrench with good success. Also helpful for phillips screws that are almost stripped. I think the real problem is the supplied wrench isn't really precisely cut on the end... :shock:
The wrench is .035 or .9mm. The .9mm is a popular 00-80 size, your LHS might have the Wiha version 26309 which also says .035"/.9mm right on it. Popular on micro helis. Or yeah, the new gears come with the tool... :wink:
