RPM trans problems?
General info, Q&A.
THE H.P FREAK
RPM trans problems?
Post by THE H.P FREAK »
HI!... In one of my recently obtained part lots I got NIP "RPM" trans cases. So I figured I'd build it with all the parts I got. So I installed a freshly rebuilt diff and Robinson Racing steel idler gear. Now I know this trans is designed for a 2.65 topgear. I don't currently have one so I decided to try the stock 2.25 top gear. It fits but the topgear and idler gear seem to bind and fit really tightly. I'm figuring this is happening due to not running the 2.65 topgear?
Has thanked: 357 times
Been thanked: 470 times
Re: RPM trans problems?
The RPM topshaft is the reason that this trans is 2.65 ( it's like a 15t ) the 2.25 stealth ( and all the other ratio's too ) use an 18T topshaft. The RPM gearbox will only work with the right top shaft
But, if it is a grey case then is is a 1.96, and uses a larger topshaft which i think is an 19 or 20-
rc10johnny
Post by rc10johnny »
Charlie don't surf wrote:The RPM topshaft is the reason that this trans is 2.65 ( it's like a 15t ) the 2.25 stealth ( and all the other ratio's too ) use an 18T topshaft. The RPM gearbox will only work with the right top shaft
1.96 =22T
2.65=17T
had a few spares.....Johnny
Well then, the Losi topshafts for the 2.43 tranny is a 17 as well 8)
