Just bought an old T3---Shock rebuild question
- Regular Member
I was wondering what it takes to rebuild these shocks. I have not had them apart, but they seem to have leaked over time. The manual shows two orings per shock. I was wondering if you can use any oring of the same size or do you have to buy a rebuild kit? Also, the manual claims that the shocks use 30W oil. Will any 30W oil work or only "special" oil?
Thanks!
Thanks!
Re: Just bought an old T3---Shock rebuild question
I would use the shock rebuild kit because it has everything to rebuild the shocks. The AE 30wt oil is not the same as other 30wt oils. I would stick with the AE synthetic oils. Just my .02
I just did mine. I found a video with a lot of tips for rebuilding the Shock and the different things you can do to outfit your ride with the course you are running on. The big thing is to replace the O-rings and clean the shaft really good. Also make sure no air gets trapped in the oil. It will cause fauler or weak points in the shock. Good luck and enjoy!!!
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
X2shane wrote:I would use the shock rebuild kit because it has everything to rebuild the shocks. The AE 30wt oil is not the same as other 30wt oils. I would stick with the AE synthetic oils. Just my .02
Jeff
- Regular Member
- 1186 Views
Last post by skipper
- 2733 Views
Last post by stingerrray
- 1043 Views
- 848 Views
Last post by GeekSpeed
- 2464 Views
Last post by HDMM
- 487 Views
Last post by RC Chick
- 24 Replies
- 3147 Views
- 725 Views
Last post by Harrylarry
