Shock Rebuild
Shock Rebuild
OK, one more question fo today....
Does somebody have a part number or a link to what I can use to rebuild my bottom load shocks? I guess if I could atleast put new orings in I would be happy for now. These are completely empty of oil right now.
Re: Shock Rebuild
1/8" silicone o-rings, available through regular hobby shops, or if you need alot of them, you can get them in bulk from mcmaster-carr for dirt cheap.
mcmaster part number 9396K11
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2594&P=7
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Shock Rebuild
and new snap rings!!!
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Re: Shock Rebuild
Mcmaster has the retaining rings too, an packs of like 50, but I don't have that off hand. Maybe someone else does.
I just re-use the rest of the stuff, with plenty of green slime.
And check the shafts. If you can see any lumpy imperfect wear on them, which is likely, you should buy new ones, and these are still readily available through all the usual channels (ebay/online hobbie shops/your better stocked lhs).
Found Giles' Mcmaster thread...but no rings on it..
http://www.rc10talk.com/viewtopic.php?f=38&t=6845&hilit=McMaster+Goodies
- Y'ernat Al
Re: Shock Rebuild
Google Advanced Search (of www.rc10talk.com) comes through again...
http://www.rc10talk.com/viewtopic.php?f=38&t=20513&view=next
- rc10johnny
Re: Shock Rebuild
you can also use traxxas shock rebuild kit it has the new bottom plastic..sorry I do not have the # off hand...JohnnySr. found it traxxas #2362
Re: Shock Rebuild
WOW, I had no idea that would work, I actually have a couple of those, I will give it a tryrc10johnny wrote:you can also use traxxas shock rebuild kit it has the new bottom plastic..sorry I do not have the # off hand...JohnnySr. found it traxxas #2362
Re: Shock Rebuild
The traxxas parts worked good....
Any ideas where to get the nylon rings for the shock caps?
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: Shock Rebuild
Joe, something in my memory is telling me that the bottom loading caps, or bodies aren't machined deep enough for the o ring's on cap side- I think-jwscab wrote:yeah, i would ditch the nylon washers and use the 1mm thick 10mm O-rings.
Re: Shock Rebuild
I'll have to double check.. I know a couple manufacturers used to sell O-rings as upgrades, and I'm pretty sure I've had them on the bottom loads without issue.
Re: Shock Rebuild
I just checked with the Orings I use from mcmaster-carr. While there is slightly less threads on a bottom load shock, there is still plenty of engagement and the Oring worked just fine.
- 848 Views
Last post by GeekSpeed
- 1043 Views
- 487 Views
Last post by RC Chick
- 737 Views
Last post by daniels9424cs
- 1483 Views
Last post by rcz
- 686 Views
Last post by Barnfind
- 725 Views
Last post by Harrylarry
- 1288 Views
Last post by AndrewSi
