Truck shock rebuild
Harrylarry
Truck shock rebuild
Post by Harrylarry »
Not to sound like a noob but I was trying to rebuild some truck shocks for a woin project. And when I disassembled them they had like 3 little washers 3 thick washers and 3 little washers. Is this normal for the trucks? I have an updated top load diagram for the buggys and i think its little washer big little but only one not stacked together. Were the using them as some limiters? Thanks in advance "gurus"
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: Truck shock rebuild
Post by JK Racing »
sounds like limiters...remember, buggies (in my opinion) should use the 1.32 rear shock body (same as truck), but 1.02 shock shaft (same as truck front shaft). you use less limiters then. if you have the 1.32 shock shaft, you will need a few limiters to shorten the shock enough for a buggy.
Harrylarry
They were truck shocks and they came from a truck lot. Just making sure that they weren't a little different internally.
Users browsing this forum: No User AvatarBing [Bot] and 4 guests
