YZ10 part numbers
- PBR Allstar
YZ10 part numbers
does anyone have a manual for a yz10 that they could possibly scan the part number breakdown page from? Or something similar for the yz 10 that gives a breakdown of the part numbers? I was looking at a YR-4 yokomo touring car and it looks like a lot of the drive parts will swap, is this the case?
- PBR Allstar
- Synergy
- Has thanked: 127 times
- Been thanked: 72 times
I'm not sure but I think I might have one for the Works 91 would that be any good
Here's my TC Showroom
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
I went over to oople and couldn't find the manuals section (again)
Tried Yokomos S site also and found them. But it looks like the car I saw was a home-made converion of an 870C or something similar.
It has the white plastic covers over the frot and rear diffs, and the the belt is guided over the battery in the rear so you can put a stick pack from left to right. Does this ring a bell to anyone?
I also saw the black wheels actually don't use hex drives: they have the recess for the pin molded in: like the old losi rear-wheels. They are definitely wider than 24 mm too and cqrry foamies. (Could 've been added later ofcourse.)
- PBR Allstar
http://www.oople.com/rc/manuals/yz870c/ there's the oople manual. It's a good scan with a really good scan of the decal sheet. As for the belt tensioners, I know some of the YR4's had that setup, so maybe that was somones stab at a YR4 conversion. lastly, the white bulkhead covers, they were white on the early cars.
ford.
ford.
- Bikerbob
The problem you guys seem to be missing is Yokomo did not publish part #s in their manuals until the YR-4 came out.
I have manuals for the 870c and the Works cars.. none of which have specific part #s that would refer to anything on a package of parts at a hobby store.
I have talked to Yokomo direct in Japan, and they do not have a LIST of 870c parts.. that they could send me.
OH well..
James
OH well..
James
- Synergy
That I think is correct, my works 91 instruction manual has no part numbers but I think I have a separate A4 sheet that does, let me know if anyone needs it and I will try to hunt it out.Bikerbob wrote:The problem you guys seem to be missing is Yokomo did not publish part #s in their manuals until the YR-4 came out.
OH well..
James
- Mr. ED
Well, the cheaper tourer was gone, (insert curse here) but I got the YR-4.
It's a real beauty, used: tires worn and some sponge dust in the diff but, spot- and scratchless otherwise. No wear on the outdrives, no play in the universals.
It looks like the seller put on all his spare parts before he sold it.
I wish I could find my camera to put up some pics.
It got a bunch of blue anodised parts and real sweet carbon chassis: lower and upper deck. So I totally binned the idea of turning it into a buggy: would be too much of a shame to put all that aside while I already have 4 buggies.
I actually found a YR-4 M2 and original YR-4 NIB in the same shop also.
I'll post them in the BST section to check if anyone's interested.
- Mr. ED
- 1686 Views
Last post by ralphee
- 1324 Views
Last post by bully
- 586 Views
Last post by bscotti
- 2354 Views
Last post by aip47-2008
- 998 Views
Last post by LTO_Dave
- 815 Views
Last post by bluewormx
- 784 Views
Last post by Corlin
- 1252 Views
Last post by atomic-carbon
Users browsing this forum: DotNetDotCom.org [Bot] and 5 guests
