YZ-10 Pavidis Edition part numbers
atomic-carbon
Post by atomic-carbon »
I am looking for some parts for my above Yok, as i may of found
a shop which may have a couple of items, but they need part numbers.
Not sure if there has ever been a list or exploded diagram around ?.
Below are the items i am looking for part numbers for, and help would be
great :D
Front belt
Rear belt
Black & White wheels
Pulleys front and rear
White spur gear
Cheers
Jonathan
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Re: YZ-10 Pavidis Edition part numbers
Post by Asso_man! »
all I can do is to offer my scanned manual, here it is: http://www.rc10talk.com/viewtopic.php?f=7&t=3801
By the way, this was my 3001st post!!!
Come and visit the stable
atomic-carbon
Thanks for the manual but it does not show part numbers :cry: , i am sure back in the day
it was always hard to work out the part numbers.
Asso_man!
Post by Asso_man! »
I know sorry. I'm not sure but I think another member had the parts list in English (mine is in Japanese)
By the way, this was my 3002nd post :mrgreen:
Dual
Has thanked: 131 times
Been thanked: 40 times
Post by Dual »
Hi Jonathan,
Bellow are the part numbers your are looking for-
Front Belt: ZD-652
Rear Belt: ZC-656
Black and White wheels: ZC-821C (front) and ZC-827C (rear). The black and white rims both shared the same part number so I guess quote the above part number and suggest whick colour you are after (the white versions are a little more rarer than the black versions).
Pulleys front and rear: ZD-503
White spur gear: I am pretty sure the part number is ASC8282. The Pavidis edition kits came with white spur gears then eventually black.
Hope this helps.
Vin
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
How many teeth do you need on the spur? I think the partnr is different for different teethnumbers.
(Could tell you for sure if they weren't all locked up in a container on a boat on the ocean :mrgreen: )
You might turn lucky by checking the partlists of earlier models YZ-10 in the archive section: in the option section
Dual
Post by Dual »
The Pavidis Edition came with a Team Associated Spur gear. The version on my own Pavidis is 81 tooth. The thing is, it does not look like the white spur gear that came with most of the RC10's. It is obviously 48 pitch but has diff ball holes in it whereas the RC10 version is blank. There was a thread about this spur gear but I can't seem to find it.
"Edit" I think the part number for the Associated spur gear is ASC8282.
Vin
atomic-carbon
Thanks for the info guys, the shop is going to check to see if they have any of these parts.
Return to “Yokomo Forum”
Users browsing this forum: No User AvatarMojeek [Bot] and 6 guests
