Size of Yokomo aftermarket spring cups
Have any of you Yokomo enthusiasts used or have these units? I'd like to know the outside diameter as well as the inside hole diameter. Thanks!
Has thanked: 356 times
Been thanked: 470 times
Re: Size of Yokomo aftermarket spring cups
I have 2 different sets, one is 15.5mm X 6mm, the other is the standard 13mm X 8mm.
Charlie don't surf wrote:I have 2 different sets, one is 15.5mm X 6mm, the other is the standard 13mm X 8mm.
I need 4 of the larger kind. :) Are yours available? And if not, what part number should I look for on eBay? I'm having a helluva time finding blue alloy spring cups in a size to fit Kyosho Gold springs... :?
Return to “Yokomo Forum”
