I got a YR-4 touring car which have the rear belt quite worn. Also you can´t read the type of belt anymore which usually is printed to the top of the belt.
Tried to search for informations but can´t find anything.
So someone have a new belt to look at or know the dimensions?
Original belts were made by Bando, but I think other manufacturers might have same dimensions.
As the rear gear box, motor mount and diff is the same type as found at some of the Yokomo offroad cars, I wonder if certain other Yokomo cars use also the same rear belt.
The YZ-870 could be same, also Works 91 or 93 maybe.
Yokomo YR-4 rear belt size vs other Yokomo cars belts
- Been thanked: 100 times
Re: Yokomo YR-4 rear belt size vs other Yokomo cars belts
OK just found the info at some other thread.
Seems to be a S3M 192mm 64 tooth.
Wide I measured around 5mm.
The question is now, which company make replacement belt like this.
I found Bando still offers that diemension but 6mm wide.
So the 5mm thing was special order from Yokomo?
- 1984 Views
Last post by aip47-2008
- 772 Views
Last post by slow_jun
- 929 Views
Last post by mikea96
- 598 Views
Last post by Alex B
- 684 Views
- 924 Views
- 1444 Views
Last post by Yokomoman
- 787 Views
Last post by Tube747
