Aluminium Spring Cups
- myfordcnc
Was wondering if anybody knew if these would fit the top loading gold shocks. If I knew the diameter that would be great. Normally I would just buy them and see but they are a little pricey so wanted to check here first.
Shock Spring Cups
Shock Spring Cups
- Has thanked: 170 times
- Been thanked: 23 times
Re: Aluminium Spring Cups
Says there for the Losi 8, which is 1/8 scale. Probably way to big. HG Hammad Ghuman made aluminum shock parts for the RC10.........a bit hard to find though.
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
check ebay item181176984173 they are for b4 shocks but they should work
My pop always said i had to many iron's in the fire
- Has thanked: 1129 times
- Been thanked: 3919 times
I thought losi springs were always larger diameter than associated but they say it works for both. Guess you will find out
- Been thanked: 4 times
TO USE losi springs u haft to use spring ring top and losi spring cup bottom,If not the spring pops up over top spring clamp or over the bottom cup.don
Agreed, but this is the other way around. That's why I was wondering if it will really fit associated springs. Worst case you could use Losi's.
- Y'ernat Al
And then you don't wear the ano off the outside of your 1:32 body by using a spring that imo, is too small.gomachv wrote:Agreed, but this is the other way around. That's why I was wondering if it will really fit associated springs. Worst case you could use Losi's.
- myfordcnc
That's a pretty good point. I had noticed that, the scraping of the shock body. I'll try both.
- 656 Views
- 1045 Views
Last post by aip47-2008
- 869 Views
Last post by mk-Zero
- 539 Views
- 1581 Views
Last post by mikea96
- 941 Views
Last post by galaxie292
- 1281 Views
Last post by XLR8
- 1006 Views
Last post by mikedealer
