Slop in 10t steering
Caine
Post by Caine »
Is it just me or is there a lot of slop in the 10t steering? Have just got my runner up together for the start of the vintage class at my local club and it seems no end of shims spacers etc will sort it out!
Any recommendations, or is there another servo saver assembly available that will suit?
Kayne
Re: Slop in 10t steering
Post by Kayne »
I think you can still get a new GT servo saver. If I am correct I think AE still makes them and it will bolt right on.
Matt
Drive It Like You Stole It!
kaiser
Post by kaiser »
there's some rpm bellcranks on tha bay, or atleast there was.
Caine
Post by Caine »
Cheers guys what would i do without you lot :D
SteveK
Post by SteveK »
The steering arms from the B2/B3/T3 also fit, but the servo needs to be turned 90 degrees to work.
You can only remove so much play from the steering; even with the bearings and hinge pins perfectly tight, there are still 8 ball and rod end connections. A seemingly imperceptible amount of play in each becomes a lot when you multiply it by 8, and that seems exaggerated when you put a truck tire on there. A little bit really isn't a problem.
Kayne
Post by Kayne »
AE part #7255,servo saver. :D
Matt
Return to “RC10 Truck Forum”
