aftermarket 10t steering bellcranks
- Has thanked: 36 times
- Been thanked: 1318 times
is there any out there for the 10t that use the long 8-32 screws like the buggy? i know the rpm bellcranks would work for what i'd need, but lotsa luck trying to find those. mip's would probably work, but they suck. how about the composite craft ones? how do those mount to the chassis?
Re: aftermarket 10t steering bellcranks
- FasterLouder
- Has thanked: 13 times
- Been thanked: 59 times
scr8p-My RC10 T2 uses an early '90's vintage A&L ball bearing bellcrank steering system that uses the 8-32 screws (I think) and works really well.
I think Valkyrie RC on eBay has a set.
Here it is:
Here it is:
- Attachments
- a&l.JPG (34.45 KiB) Viewed 915 times
All The Way Alive
they would work on a 10t, but you'd have to mount the a&l kit to the front bellcrank holes on the nose plate first. then, mount the noseplate to the chassis using the rear holes in the nose plate. the 10t bellcranks are twice as long then standard buggy bellcranks, because it used the buggy tub chassis. the t2 chassis is longer, so you can use a buggy bellcrank and it doesn't look like you had to make something work.
all of daryl's a&l/factory works steering kits used the same yellow plastic bellcranks. the only diffrence in the kits were the sector arm and the drill template included with some kits to relocate the 'cranks where needed. i bought a kit one time off ebay for a yokome touring car just to replace a broken 'crank half. the good thing about the kits was they came with a left,right, and straight arm 'cause he moluded all three together.
- 617 Views
Last post by tecnica2001
- 585 Views
Last post by JosephS
- 3808 Views
Last post by Lonestar
- 1624 Views
- 1248 Views
Last post by XLR8
- 1442 Views
Last post by radioactivity
- 731 Views
Last post by Kayne
- 884 Views
