How much torque does a 10t steering servo need?
- Has thanked: 1243 times
- Been thanked: 639 times
So I am running my Rc10t with the turnigy 1258tg with a reported 13.5 kg of torque.
At a complete standstill on pavement the front wheels are challenged and don’t fully turn. When driving it seems fine.
Should the wheels freely, or fully, turn when on the ground? How do I tell if I have enough torque on the steering servo?
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2095 times
Re: How much torque does a 10t steering servo need?
If the ratings of that servo are remotely close, it should be more than enough.
I'd check for bind in the bellcranks. Its easy to over-tighten them.
If you are using original 10T length bellcranks, the geometry on them is horrible. A set of buggy bellcranks, mounted in the foreword holes is much better. My runner truck has Worlds bellcranks on it.
- juicedcoupe
And be careful when selecting a servo horn.
A longer horn gives the servo less effective torque. And you just end up dialing the endpoints way back to control travel.
- juicedcoupe
Just for reference, I checked the steering on my Team Truck. It still uses the original steering.
With a Futaba S9304 (about 5kg), it had no issues turning while sitting still.
I also checked my runner truck with Worlds bellcranks and a Tower Pro MG-995 (about 11kg). It will easily snap the tires back and forth while sitting still.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Pop the ball cup off the servo horn and check for binding, check that the servo saver isn't too loose, then try the servo while the steering is disconnected. This should tell you where the problem is.
The problem was the second servo saver I was using. I was using servo an older kimbrough servo saver instead of a servo horn. I swapped up to a standard piece of plastic and all is well now.
But it sounds like anywhere from 5-10 kg is going to be enough.
I think the old off brand servo wasn't even close to it's rated specs.
I just switched out to the servo from my buggy an official Savox 1258tg https://www.savoxusa.com/products/savsc1258tg-std-size-coreless-digitaland the difference in handling is night and day.
- 1481 Views
Last post by JK Racing
- 2044 Views
Last post by soniccj5
- 874 Views
Last post by fiveonomo
- 1417 Views
Last post by Chewbacca
- 735 Views
Last post by DHC6
- 1099 Views
Last post by Johnboy72
- 3270 Views
Last post by klavy69
- 2419 Views
Last post by yellowdatsun
