Tranny Issues?
thegame310
Tranny Issues?
Post by thegame310 »
Hi guys,
Having a bit of a transmission issue with my 10T
It's been sitting for a while and I purchased a Mamba Max for it brushless system and it runs great, now however when I put the truck down on the ground it seems to barely go at all...essentially it creeps. However, when I pick the truck up and gas it the tires spin like hell...any ideas on the problem?
shodog
Been thanked: 91 times
Re: Tranny Issues?
Post by shodog »
Sounds like either your diff is loose or the heat generated by you last run melted the diff gear
thegame310
Re: Tranny Issues?
Negative on it being lose, and the diff isnt melted.
Possible slipper clutch?
Has thanked: 356 times
Been thanked: 470 times
Re: Tranny Issues?
Then, your other possibilities are-
1) split wheel on either side allowing the axel to spin inside the wheel it should be turning
2) missing or broken drive pin
3) spit slipper pin
4) glazed slipper pads
5) incorrect slipper arrangement
Return to “RC10 Truck Forum”
