RC10B2 tranny, re-build / issues
Ondapre  It’s my birthday!
Has thanked: 12 times
Post by Ondapre »
Hey I would like to see if anyone has answers to my trans minor issue. I have built it a couple times, but it has sat for a while (5+ years) If I go slow with throttle I can prevent the "slip" sound. It is like a low tone screech. Both gears outside of the transmission have not been worn down.
Asking advice on whether to get another trans or to re-build with proper grease etc? Thanks!
Has thanked: 355 times
Been thanked: 470 times
Re: RC10B2 tranny, re-build / issues
Assuming the slipper is set properly, sounds like your diff is to loose, 5/64 driver on the left transmission drive cup, turn until completely tight, back off 1/8 turn (about 2 hours) and you should be good to go.
Post by Ondapre »
awesome I will do that thank you! I runs great no grinding, nothing. Just slips real bad when full throttle off the start. When running in grass it will do the do the slipping sound on and off randomly.
morrisey0
Has thanked: 87 times
Been thanked: 1847 times
Post by morrisey0 »
Charlie don't surf wrote: Wed Jun 04, 2025 9:02 pm back off 1/8 turn (about 2 hours)
That is a slow slow slow turn!!!! 1/16 an hour; that is hard to break down into minutes, even less seconds!! :wink:
morrisey0 wrote: Wed Jun 04, 2025 9:16 pm
Bwhahahhaha
Post by Ondapre »
Charlie don't surf wrote: Wed Jun 04, 2025 9:23 pm
Bwhahahhaha
Ok so your saying I need to tighten it for 2 hours? ;) hehe Once the buggy has momentum no slip or squeal. If a turn slow down and run again I get the squeal.
Post by Ondapre »
So recommendations? I should re-build it, re-grease it etc. Is there a site or anyone have any info on re-building it properly :)
Has thanked: 2604 times
Been thanked: 2976 times
bluewormx
Has thanked: 41 times
Been thanked: 91 times
Post by bluewormx »
bluewormx
Post by bluewormx »
Hi, the most important thing is that the main differential balls have to be greased with the proper stealth diff lube.
Any other kind grease will produce your original symptom.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
You definitely don't want to apply the wrong grease to your balls.
Post by Ondapre »
bluewormx wrote: Sat Jun 07, 2025 2:27 am Hi, the most important thing is that the main differential balls have to be greased with the proper stealth diff lube.
Yes, I figured I needed to basically re-build/grease inside the tranns.
When I slam the pedal to the metal it will sweal under I let off the trigger and slow the RPMs
Post by Ondapre »
I still have the OG grease for everything that needs it in the B2 :)
Users browsing this forum: No User AvatarCCristo, No User AvatarSemrush [Bot] and 2 guests
