RC10 Issues
Bent
RC10 Issues
Post by Bent »
Ok guys I'm having a few issues with my old rc10. I decided to do a full tear down and clean it up go through the trans and all. Thats just what I did, the trans is good and has fresh lube, the bearings are good, the carriers and all that is good. Diff is good. I then installed all the gear and Reprogrammed and reset the servo and esc.
The problem I have is when I spin the motor off the ground it is good and smooth and the motor is strong. I then take it out walk all the way to my track set it down and it crawls. Some times when I turn it kiks and takes off but not everytime. What could be causing this? I have a 13x2 motor with a LRP no limit icp pro esc.
You run me in the grass imma run you in the wall, drive like a racer not a flippin idiot
THIS PLACE ROCKS!!!!
RC10resto
Has thanked: 1488 times
Been thanked: 550 times
Re: RC10 Issues
Post by RC10resto »
try another motor
Bent
Re: RC10 Issues
Post by Bent »
Same thing.
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Re: RC10 Issues
Post by Asso_man! »
Sounds more like a servo or radio problem to me, do you have capacitors on the motor? Replace the servo, if still not solved, the receiver and the radio.
Come and visit the stable
Bent
Re: RC10 Issues
Post by Bent »
Asso_man! I do have capacitors on the motor. The servo is out of my old 1/8th scale it is a high tech HS-645mg. But as I said it doesnt do it all the time. I will check the receiver it is an old futaba am with Traxxas crystals.
Also how would you guys suggest bracing the chassis.
soniccj5
Re: RC10 Issues
Post by soniccj5 »
Sounds like the old school glitching problem. If the servo you have is high power, it could be causing the problem. Some of the higher power servos need an extra capacitor to help power them.
If it is in the budget I highly recommend upgrading to a 2.4Ghz radio system. After I upgraded to brushless I could not even drive the car because of all the glitching.
As for bracing the chassis, I really like the A&L Chassis stiffeners, which are still available through Daryl Lane.
Bent
Re: RC10 Issues
Post by Bent »
Here is a shot of the car, I don't think it is a high torque but it may be. I have thought about a 2.4 it would make things much easyer but its just not in the cards right now.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: RC10 Issues
Post by klavy69 »
bracing that chassis might be a project in itself. Maybe you could build some kind of a 'top plate' like on a yokomo to go over all the electronics and attach in front of front shock tower somehow :?
Has thanked: 356 times
Been thanked: 470 times
Re: RC10 Issues
The pig curled blue wire off that IPC SR is a digital servo lead, if it touches something conductive it will glitch at best, fry the speedo at worst. Caps on the motor with.that AM system is s must.
Bent
Re: RC10 Issues
Post by Bent »
Charlie what would you suggest I do with that blue wire? I curled it to Help keep it from touching anything.
Klavy WOW, really?
RC104ever
Re: RC10 Issues
Post by RC104ever »
What kind of battery are you using? Looks like a Nimh. You might try a cheap lipo instead.
- Chris
Lots of cars...so many cars
Bent
Re: RC10 Issues
Post by Bent »
Yes it is a nimh and 2 new lipos and lipo charger isnt in the cards right now
Goatless
Re: RC10 Issues
Post by Goatless »
Bent wrote:Here is a shot of the car, I don't think it is a high torque but it may be. I have thought about a 2.4 it would make things much easyer but its just not in the cards right now.
The Hitec 645 is a Hi Torque servo.
Sounds to me like the brushes are bad if it needs a push to get going.
"I'm like the fat girl at the prom, just glad to be here!!!
Southern Fried Racing : The Sequel
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Re: RC10 Issues
Post by adam lancia »
Commutator probably needs a cut and the brush springs might need replacing too.
Bent
Re: RC10 Issues
Post by Bent »
Ok guys swapped esc radio and receiver problem solved swapped back to my radio np put my esc back in no problem. 2nd charge for the day it started doing it again.
