Can hydra drive fit to JRX pro se?
crusaderlyf
Post by crusaderlyf »
I got a losi vintage car,that seen jrx pro se mold chassis,but slipper I known that is
losi hydra drive. I knew hydra drive come from losi xx,is that any conversion parts will make it fit
to losi jrx pro se?
kenooze  It’s my birthday!
Re: Can hydra drive fit to JRX pro se?
Post by kenooze »
It depends about what gear box you used on your Pro-SE !
slapshot1979
Post by slapshot1979 »
My Pro SE has the 2.19:1 tranny with a HYDRA drive, So yup its do-able
crusaderlyf
slapshot1979 wrote:My Pro SE has the 2.19:1 tranny with a HYDRA drive, So yup its do-able
I understood, thanks for your help
Brandon G
Post by Brandon G »
That is what the Hydradrive was originally designed to go on. Production issues with the tolerances of the impeller and outer housing delayed it going into the SE kits. As long as you have the proper Hydra top shaft, it will work on either tranny.
Return to “Losi Forum”
Users browsing this forum: No User AvatarBing [Bot] and 5 guests
