I'm trying to wrap my little brain around the hydra drive.
I thought that the unit itself acted like a torque converter, using the fluid within to act as a slipper clutch.
But then why do you install the hydra drive unit on top of another slipper plate and pad?
Help!
Hydra Drive Noob Q
Re: Hydra Drive Noob Q
the hydra allows you to set your friction slipper more loosely then you typically do with friction pad only, giving you better traction on tracks with rapidly changing conditions.
it gets complicated from there, but it basically allows you to mix together a linear slipping action and an exponential slipping action. It can be tuned out by simply tightening the slipper clutch, so having both gives you flexibility.
- 1431 Views
Last post by Synergy
- 690 Views
Last post by radioactivity
- 1540 Views
Last post by bgruen
- 904 Views
Last post by joel45acp
- 843 Views
Last post by Lonestar
- 1267 Views
Last post by brian s
- 2581 Views
Last post by mytimac
- 272 Views
Last post by jcwrks
