Hydra slipper fluid question
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Post by minimini »
I got a Losi hydra slipper .........but with all leaking out of the fluid ...........:(
anyone knows what degree of shock oil is compatible with the slipper fluid ??........:)
many thanks !!.........:)
DerbyDan
Been thanked: 19 times
Re: Hydra slipper fluid question
Post by DerbyDan »
I've heard 1000wt geared diff oil is the stuff to go for.... but that was something I read on another forum, i.e I haven't tried it myself :|
I might give the Hydra another go on my CR2 - back when we ran the first edition XXs we all junked our leaky hydradrives in favour for the simpler (& less messy) friction set-up.... now everyone wants them again :D
drbelleville
Post by drbelleville »
As far as leaks, this may be a dumb question, but have you tried putting a light coat of Silicone lube on the seals? Back when I had my Pro, I would put a bit of the silicone on the O-rings and seals, just enough to help seal, not too much to impair the "Impeller" of the Hydra Drive. You can find it at the hardware store, I got mine from lowes, I think it was called "Silicone Plumbers Lube". I use it now when rebuilding my shocks and 1:8 diffs.
Just a shot in the dark here.
Return to “Losi Forum”
Users browsing this forum: User avatarFrankentruck and 5 guests
