rc10 stealth hydra drive question need help
- Has thanked: 25 times
- Been thanked: 143 times
i want to use the losi style hydra drive setup on the rc10 stealth trans. http://www.ebay.com/itm/Thorp-4774-Adapter-Kit-64-Pitch-HydraDrive-Team-Associated-RC10-RC10-/251547939843 so i need this shaft and this should be able to fit the losi dydra drive setup? http://www.ebay.com/itm/losi-hydra-drive-unit-complete-vintage-losi-vintage-rc-car-/151330013703 (pics i found off ebay)
- Has thanked: 36 times
- Been thanked: 1318 times
Re: rc10 stealth hydra drive question need help
if you have a 64 pitch diff gear and idler it'll work.
you will need this.
the thorp you posted is for 64 Pitch, unless you have a 64 pitch internals then its a match.
― Confucius
― Confucius
they also sell a 48 pitch http://www.ebay.com/itm/Thorp-4775-Adapter-Kit-48-Pitch-Hydra-Drive-Team-Associated-RC10-RC-10-/400720448871?pt=Radio_Control_Parts_Accessories&hash=item5d4ccccd67 either one will work in a stock stealth trans with stock internal gears?
so is that different than the ones i have listed on here from ebay?
yup
― Confucius
― Confucius
same function different manufacturer, one you showed from Thorp, mine posted came from LOSI.
― Confucius
― Confucius
by right is should, not unless the item was misrepresented to be for another carhugger19 wrote:hum ok........so than that fits in the stealth trans than i can bolt up the losi hydra unit with no issues.
it should do the job as expected. cheers..
― Confucius
― Confucius
- 1935 Views
Last post by phoenix
- 690 Views
Last post by radioactivity
- 814 Views
Last post by 17nut
- 624 Views
Last post by ThomasH
- 906 Views
Last post by mrlexan
- 600 Views
Last post by Jerzi
- 830 Views
Last post by slow_jun
- 1431 Views
Last post by Synergy
Users browsing this forum: Bing [Bot] and 3 guests
