How many versions of the RC10T were there?
highwayracer
Been thanked: 6 times
Post by highwayracer »
hello All,
I recently went to a hobby shop that had a NIB RC10T. The box was open, so I was able to see all of the parts. Let me tell ya, there's nothing like seeing a NIB example and going through the parts.
I guess I left the hobby (temporarily) before the different versions of the 10T came out. I was surprised to see that this 10T had black parts (arms) and one piece wheels. The arms were the flat version that came with the T2 and not the webbed versions. Everything was still NIP, so I knew it wasn't swapped out.
So the question is, what version is this? In all of the excitment, I didn't take note of the kit number :oops:
Any information would be greatly appreciated.
Regards,
Roger
cyclepsych0
Re: How many versions of the RC10T were there?
Post by cyclepsych0 »
More than likely is was one of the last runs of the 7035 team truck. AE changed to all black parts on their last of the 10's and 10T's as the B2 and T2 were being phased in. I say team truck because you mentioned 1-piece wheels. Sport trucks would have still had 3-peice wheels, gold-bodied shocks and bushings instead of bearings.... 8)
longboardnj
Post by longboardnj »
as far as rc10t goes i think 8 ... here is how i thought of that answer.. you have the first white arm then the second white arm (different shock mounts up front, maybe even 3 white arms) then they took the white arms and made them black,then they made a new style black arm (like t2) ... now that was 4 and x2 cause each came as a sport or a team... someone please let me know if im correct...
skunk.werkz
Post by skunk.werkz »
The only differences I know minus going through each variation like sport/team/factory..there were the early trucks with the narrow front wheels that were banned, thin webbed a-arms and thin shock towers (in white) and then they came out with thicker webbed arms and thicker towers.
Has thanked: 356 times
Been thanked: 470 times
7001- Early RC10T
1) Early B stamp offset battery, early ball cups, early stealth brace, paper thin non webbed
arms, thin shock towers,15 deg steering blocks and Pro-55/Pro-90/& narrow tires
2) Same chassis, ball cups, thin webbed arms, standard stealth brace, 20 deg blocks, T/A
narrow/multi rib/paddle spike rears. Both with AE 6122 body
7035- RC10T Team Truck
1) In line B stamp, full hex ball cups, standard nylon stealth brace, 20 deg blocks, thin
webbed arms, thin 2 hole towers, Narrow/multi/paddle tires
2) Same but with thick webbed updated arms, thicker 3 hole front/4 hole rear tower
aluminum front inline axles and 30 deg blocks, plus universals
3) C stamp, same as above but black composite thick webbed arms, graphite stealth
brace. And solid wheels plus multi rib front/Pro-90 All with the 6135 team truck body
7011- RC10T sport truck
1) B stamp, same as #1 7035 except thick webbed arms, Gold shocks, MSC and 6122
shell
2) C stamp, same as above but thick black composite arms, and graphite brace
3) C stamp, all black with t2 type arms and composite towers
6 different types of arms- 3 towers /thin non webbed, thin webbed, medium webbed and thick webbed and black composite thick webbed ( not T2 type ) and late T2 type
longboardnj
wow i had no idea... the most i thought of was maybe 5, 3 white sets , a black set same style as white and 1 new style black set.. what am i missing???from what i read from your post are you saying 4 white arms??? oh and great info
Yes, 4 different white arms-possibly even 5 white arms if you count the late white w/the shiny composite fibers in them
highwayracer
Thank you for the information. I just need to see if I can get the truck for a decent price.
Regards,
Roger
Soncho Ponza
Post by Soncho Ponza »
Show some pics. A saw a time ago a thread with shots of the diff early arms from the Ts. who did that.
I will get some up next week, Ruffy had some prototype ones that he had showed in the buggy forum a while back as well
Some of em'
earliest 10t arms, very thin and no radiused webbbing
First revision, radiused webbing only change ( look at top view arm )
Second revision, radiused webbing and thicker
Third revision, same as NIP, but thicker yet and more material in weak spots
Same as above
last arm of this design for the 10t, same material as the worlds arms w/ fibers
More info an pics to come-----
Bolt
Post by Bolt »
sweet so according to this I have a 7035-C RC10T Team Truck
It appears to be, but that rear body mount looks like a Thunder Tiger part :lol: Yours is the last version sold with the GT/T2 type arms and the revised rear bulkhead.
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
Reg, I think the first GT's used the same arms as the 3rd and 4th 10T. It was not until the T2 that the arms got revamped and placed on GT's and very late 10T's.
Bolt
Post by Bolt »
do you guys know the production years on the different models?
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAhrefs [Bot] and 3 guests
