what kinda servos fit in an RC10B2????
So I have this B2 I picked up as a roller, and just happened to try and stick a steering servo in the car. I think it was an S128 or S148 futuba servo, standard size. It wouldn't quite fit in the small space for a servo. I checked the manual but they don't specify a specific size of servo.
so what is a good candidate to stick in this car??? A micro OR mini size?
- slotcarrod
- Been thanked: 45 times
Re: what kinda servos fit in an RC10B2????
Any standard servo will fit! The S148 should drop right in! I use a Futaba S9550 in mine and it's a standard width! You may need to used the spacers that come with the OEM servo mounts to move it forward!
Rod Littau
I'll have to check again, I must be losing it. It seemed like the servo just wouldn't fit, both front to back, and side to side. maybe it's just that close?
- Regular Member
They are a tight fit in the B2.
The B2 is the only car I use.
First servo was Airtronics XL2P
servo #94102
I now use Towerpro SG5010 Standard Servo
Dimension: 40.2x20.2x43.2mm (1.57x0.79x1.44in)
Works very well for $6
servo #94102
- Been thanked: 81 times
X2 . I have the S148 in my car and I used the thin spacers. If you don't have the spacers tower sell the servo mount. I think they have it listed as a T2 servo mount.Post some pics of the car when to get it finished.slotcarrod wrote:Any standard servo will fit! The S148 should drop right in! I use a Futaba S9550 in mine and it's a standard width! You may need to used the spacers that come with the OEM servo mounts to move it forward!
so i checked again, and they do fit, but it is tight! I have an S128 that has been used and the ears are slightly enlarged from using the wrong hardware, and it won't fit unless i trim a tiny bit of the ears. I have a brand new S3003 that JUST fits in there.
- Regular Member
Good to hear you got it worked out.
Since it does fit in so tight,
it will be the last thing to fall out when doing cartwheels !!!!!
- 1266 Views
Last post by mrlexan
- 1252 Views
Last post by keithc6
- 1254 Views
Last post by HDMM
- 19 Replies
- 4015 Views
Last post by zuki250
- 972 Views
Last post by matt1ptkn
- 678 Views
Last post by y2kgtp
- 1547 Views
Last post by jonboy
- 2152 Views
Last post by Bugle
