JRXT build, kinda
- Has thanked: 194 times
- Been thanked: 48 times
JRXT build, kinda
The old "I'll make this pile of parts into a truck for next to nothing" scheme
But it never goes that way, found some old RPM JRXT conversion arms and well, then it starts (dremel used to make e-clip grooves)
A little metal restoration/bluing (Ended up only using the drive cups & axles from this batch)
Used XXX aluminum dogbones, along with some axle spacers mounted inboard to make them work
Shorter arms means shorter turnbuckles, fortunately Lunsford still makes retro turnbuckles!
The truck as it sits. I think it's a Composite Craft chassis, used a Sabula Tech blue screw kit, Old RC carbon towers, some Pro-Line LXT wheels & a JRXT body painted by Andy Jacobson (the reason for the build was basically to display the wheels/body)
Short RPM rod ends in the mail for the steering link, and these old electronics are going in soon. What do I do with 32" of antenna though!?
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: JRXT build, kinda
I use a lot of these.
https://www.amainhobbies.com/traxxas-vinyl-antenna-caps-w-antenna-spool-tra1926/p-qtqxqzqqxzxxactz
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
Beautiful truck! I've had many creative memories tied up in receiver wires.
Matt
- 1250 Views
Last post by HDMM
- 2651 Views
Last post by bearrickster
- 1980 Views
Last post by BattleTrak
- 1101 Views
Last post by Doc J33P
- 34 Replies
- 8892 Views
Last post by Lurker
- 1499 Views
Last post by Mike DeLaney
- 1264 Views
Last post by mrlexan
- 1249 Views
Last post by keithc6
