Buds orange CAT belt
I've got an orange belt by Buds Racing Products. Does anyone know how these are better than the kit item? It feels more plastic and less "belt" like (?)
Also, looking for some new CAT driveshafts (not one ways) ta.
Luke
Luke
Re: Buds orange CAT belt
The orange or red series of urethane belts were produced and sold by several manufacturers. They do vary chemicaly (slightly) from company to company in thier makeup. However as far as you are concerned it doesn't matter. They offer less rolling resistance, stretch, and a better tooth form compared to the stock (neoprene) kit units. This translates to a more efficient car with less servicing. These belts will also last many times longer than the stock kit belt. I ran one belt in all of my Schumacher cars (even though I sold them myself). From my original XLS up through my procat (s). I put HUNDREDS of runs on it, and it still looks good to day (20 plus years later). -Jeff
I see. Thanks Jay. I'll install it next time I rebuild the transmission.
Know anyone who's got some new CAT driveshafts?
Hi Jeff
I'm just rebuilding the transmission on my Procat (takes ages!) and got out the orange belt, voila...
I'm racing it again on Sunday - you reckon I should definitely fit the orange belt? Someone said they can be more slippy - but my standard belt doesn't slip - got it set up sweet.
If you have an orange belt run it! I do not think they are more "slippy". In fact because of soft teeth on the stock neopreen belt, it will quickly become frayed, and more "slippy" than any of the orange type belts. I would say that when new both belts are about the same in that department, but the orange belts quickly surpass the stock belts. One thing also that people don't understand is that by nature, belts are intended to be run tight. If a belt has too much play, then the mesh between the belt and its pulley can become a problem. As torque is applied to the drive line, the belt will want to climb away from its mating teeth (read skip), and there will be a pitch difference between the belt and the pulley (belt = a larger raduis, and the pulley's radius stays the same). This will quickly want to wear a belt out, and round over pulley teeth. This is where the orange belt really shines, because it can be run tight, and remain efficient because of the materials it is made of. -Jeff
Jay speaks the truth there especially on these fine pitch belts run them tight otherwise you will do more damage. In reality it was probably too fine a pitch for it to be run in an offroad buggy. Even touring cars nowadays have much coarser belts to withstand modern BL techonology. I remember standing near the end of the straight at the TITC race in Thailand and the likes of Surikan and Andy Moore duking it out. You could hear the clacking sounds of slipping belts as they jam on the brakes, I guess running alloy pulleys, front spools and 3.5 turn motors will do it.
Thanks guys. Instead of using the kit belt tensioner (which wasn't very effective) I've put spacers between the front gearbox and housing brackets. I reckon my belt needs a spacer of about 3mm to run right. There was a detailed tuning article on the Procat. I've got a hard copy but I've forgotten what website I got it from. Isobarik mentioned it in the "XLS vintage racer" thread.
The orange belt seems a bit longer so I had to move the front gearbox forward a little more. Got some 1.5mm thick plastic off eBay and cut some spacers.
I will be building a "Procat" racer in the near future, and will be using the std pitch belts (all orange however). If I had my way, I would use all Bosscat belts, and diff components. I am just not sure if they can be fitted to the front however.
. -Jeff
The Bosscat rear pro-diff fits the Procat and is the best diff - smoother than the MMS nylon diff plus it's sealed. Will you run the heavy duty 7mm belts in the rear? I've been using the 5mm ones and havn't slipped yet. Is it worth getting a set of 7mm belts? I assume these can handle more power.
Yes they can handle more power, but they will increase driveline drag
. This may or may not be an issue, as many brushless systems have very little cogging or natural "drag brake" and need to have drag brake added. -Jeff
Re: on eBay
Cheers !!kaszal wrote:Heads up on a BRP belt...
http://cgi.ebay.co.uk/Schumacher-CAT-XL-Buds-Ultra-drive-Belt-long-lasting-/200517057818?pt=Radio_Control_Parts_Accessories&hash=item2eafbf7d1a
Hi Carl, that orange belt will go nicely with your new motor plates
Proper bullet-proof transmission.
Hey Luke,
Yes it will !! the plates should arrive any day I expect
thanks !
Carl
Carl
- 1992 Views
Last post by aip47-2008
- 24 Replies
- 4109 Views
Last post by kaszal
- 2217 Views
Last post by kaszal
- 1173 Views
Last post by stephenianjames
- 384 Views
Last post by Jay Dub
- 814 Views
Last post by Mr. ED
- 767 Views
Last post by Kcal
- 4110 Views
Last post by Mad Racer
