rpm gearbox
rpm gearbox
I have a few b2 and b3's for parts and was wondering if I can use the rpm gear ratio change box and the guts from the b2 trannys to make a cheap stealth transmission?
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: rpm gearbox
Nope, the RPM conversion changes the ratio via the top shaft, the B2 ratio change was via the diff gear
- burnsmonkey
Re: rpm gearbox
Hay Charlie dont surf, what wheels are on your gold pan in your avatar?Charlie don't surf wrote:Nope, the RPM conversion changes the ratio via the top shaft, the B2 ratio change was via the diff gear
- PBR Allstar
Re: rpm gearbox
Those are stock 3 piece C.E. (championship edition) wheelsburnsmonkey wrote:Hay Charlie dont surf, what wheels are on your gold pan in your avatar?Charlie don't surf wrote:Nope, the RPM conversion changes the ratio via the top shaft, the B2 ratio change was via the diff gear
- burnsmonkey
Re: rpm gearbox
Thank you, I have a set of those and was wondering where they came from.PBR Allstar wrote:Those are stock 3 piece C.E. (championship edition) wheelsburnsmonkey wrote:Hay Charlie dont surf, what wheels are on your gold pan in your avatar?Charlie don't surf wrote:Nope, the RPM conversion changes the ratio via the top shaft, the B2 ratio change was via the diff gear
Re: rpm gearbox
will the gears out of a b4 work?Charlie don't surf wrote:Nope, the RPM conversion changes the ratio via the top shaft, the B2 ratio change was via the diff gear
Thunder Turtle Racing
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: rpm gearbox
thanks for the info. what associated car uses the 2.25 stealth. trying to find out so i can round up some parts.LowClassCC wrote:nope the b2 2.4 stealth diff is a different size than the 2.25 stealth
- LowClassCC
Re: rpm gearbox
buggies
rc10 ce stealth edition
rc10 team car
rc10 worlds edition
trucks
rc10t
btw you can still get all the stealth parts new from tower.
rc10 team car
rc10 worlds edition
trucks
rc10t
Re: rpm gearbox
LowClassCC wrote:buggies
rc10 team car
rc10 worlds edition
trucks
rc10t
Thanks you guys rock
- 1613 Views
Last post by RC10th
- 1838 Views
Last post by drbelleville
- 880 Views
Last post by walfre
- 719 Views
Last post by esaresky75
- 567 Views
Last post by klavy69
- 682 Views
Last post by ThomasH
- 2771 Views
- 1623 Views
Last post by lmw94002
