Gearbox Cover
- esaresky75
Gearbox Cover
On the Raider, Rocky & Turbo Rocky, the rear gearbox cover is aluminum to act as a heatsink for the manual speed control's resister. I had a factory Kyosho black plastic cover that did not have the resister mounts but no longer have it. Anyone know the part number of that cover or what model used it?
Burn more coal - UnderGroundMiners.com
- Lowgear
- Has thanked: 121 times
- Been thanked: 796 times
Re: Gearbox Cover
The Raider's was actually plastic. I don't know what if any model used the same cover without the resister mount. The one for the Raider comes in the RD-12 bag.
- esaresky75
Re: Gearbox Cover
Thanks, I thought it was also aluminum. I will share something I learned. While cleaning the plastic parts of a Turbo Rocky, I was using Berkible carburetor cleaner on the parts (thay had some dark film that hot water/Dawn wouldn't touch) but only after testing it on a small area because it can damage some types of plastic. All was well until I cleaned the gearbox plastic cover (I knew it wasn't for the Turbo Rocky), the cleaner damaged it. So the plastic used on that cover is not chemical resistant but the rest are.
- 1006 Views
Last post by mikedealer
- 880 Views
Last post by walfre
- 1070 Views
Last post by Hillbillyrcer
- 753 Views
Last post by rawpwr
- 447 Views
Last post by tjf
- 23 Replies
- 2752 Views
Last post by chophead69
- 663 Views
Last post by rctenracer
- 573 Views
Last post by dinglem
Users browsing this forum: Tbot [Bot] and 4 guests
