Will newer model shock rebuild kits work on gold shocks?
General info, Q&A.
speedemall
Post by speedemall »
I need a shock rebuild kit for a set of gold shocks. Will the newer RC10 rebuild kits work on these? IE B2,B3?? Is the original rebuild kit still in production?
They call me.........THE COLLECTOR!! Collector and restorer of everything vintage
Brandon G
Re: Will newer model shock rebuild kits work on gold shocks?
Post by Brandon G »
The current rebuild kits will work with ANY of the associated top load shocks.
However, on the original bottom load shocks, you will need to retain the bottom plastic washer and c clip for reuse. The o-rings and teflon spacers in the new rebuild kits can still be used to get them back into shape though.
If you need the c clips, they can be purchased from McMaster Carr or Grainger.
strangersinspace
Post by strangersinspace »
Brandon G wrote:However, on the original bottom load shocks, you will need to retain the bottom plastic washer and c clip for reuse.
There is a Traxxas shock rebuild kit that you can use to replace the bottom plastic washer and the larger c-clip. Fits like a champ. Between that and some new o-rings, you're set.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ17&P=ML
Users browsing this forum: No User AvatarGoogle Adsense [Bot], No User AvatarMojeek [Bot] and 6 guests
