team losi
rcfan
team losi
Post by rcfan »
what newer diffs will fit in a team losi junior t?
highwayracer
Been thanked: 6 times
Re: team losi
Post by highwayracer »
hello,
There are 2 ways to answer this question.
1. What newer transmissions/diffs will fit in the junior t? Losi made a Double X retrofit transmission that will bolt directly into the junior t. Losi made 2 different ratios (tuck and buggy). This is different than the transmisson in the XX. There was also an MIP transmission, but that was older than the XX retro fit.
2. What parts from a newer transmission/diffs will fit in a junior t? The original 6 gear losi transmission (also know as the LRM...Low Rotating Mass) doesn't really share parts with any other transmission. The only thing that you can probably swap out would be diff balls. The balls in the thrust bearing (newer style) might be used on a newer type of transmission...but I'm not sure which cars use this.
I hope this helps...
Regards,
highwayracer
Return to “Losi Forum”
Users browsing this forum: User avatarFrankentruck and 6 guests
