Losi Tyres Forum
Keyz
Losi Tyres Forum
Post by Keyz »
I will be modifying this post as I can, but it is a personal reference for Losi Tyres I thought I'd share. Add info if you wish and I'll mod this post. Pics of treads are most welcome if there are none available!
Will add info on generation of chassis that the tyres came out around.
Will be checking my mags for info too.
It occured to me there are a plethora of Losi Tyres I have never seen before, so have started this reference thread for anyone else with a rubber fetish like me :P Let me know what you think of the topic.
2wd Front
JRX2/Pro/SE
7200 Ribbed K compound (JRX2)
7210 Stagger Rib K compound
7211 Stagger Rib HT compound and on (JRX Pro/SE)
7221 6 row spike
7231 Full Radius Rib
XX Onwards
7201 Ribbed HT compound and on (XX)
7202 Wide Body Rib (XXCR)
7203 X Wide Body Rib (Triple X)
BK Pre scrubbed 2 Rib
BK Pre scrubbed 3 Rib
Taper Pin
4wd Front
Blockhead
Sprint
IFMAR Pin (XX4/WE)
IFMAR Stud
Taper Pin (XXX4)
2 & 4wd Rear
2.0 inch
7300 4 Row spike K (JRX2)
7301 4 Row spike HT
7321 X Pattern (JRX-Pro)
7351 6 Row spike
Step Pin
2.2 inch
7352 Micro Step Pin (? pics info appreciated)
7355 Step Pin (? pics info appreciated)
7364 IFMAR Stud (XX)
7373 Mini Step Pins (? pics info appreciated)
X-2000 (XXXCR)
Taper Pin (XXX/XXX4)
IFMAR Pin (XX4/WE)
X-3000
Sprint
Truck Front
7500 Rib (JRXT/LXT)
7502 Full Radius Rib "Diamond Series"
7510 Stagger Rib
Truck Rear
7600 6 Row Spike (JRXT/LXT)
7610 X Pattern
7620 Mini Pin
7630 10 Row
7632 6 row "Diamond Series"
7634 12 Row "Diamond Series"
Step Pin
Reptile
X2000
Taper Pin
Edits:added from lists thanks
Bongo Fury
Re: Losi Tyres Forum
Post by Bongo Fury »
The price lists in the archive have tire info for the first few years:
http://www.rc10talk.com/viewtopic.php?f=7&t=6366&start=0
Did Losi ever do a 2.2 step pin, I only recall seeing 2.0???
kenooze
Post by kenooze »
the X tra wide body was 7204 and not 7203
About 2.2 rear tyres you miss the Big Shot and the BK bar (the story of this tyres was so funny)
I try to complete your list with pictures asap
kenooze
Post by kenooze »
About 2.0 inch, you could had
A-7341 Rears, Directional pattern (H.T.)
A-????
A-7321 Rears, "X" pattern (H.T. compound) 2
About 2.2 inch, you could had to the previous A-7321
A-7358 NEW 2.2 rear, "X" pattern
A-7355 NEW 2.2 rear, step-pin
A-7370 2.2 rear "IFMAR DASH" (silver)
m2fit4u2
Post by m2fit4u2 »
I have a question and figuard this would be the appropriate place. I have a set of Losi X pattern "cushion carcass" tires that I plan on mounting onto some rims. It seems to me with how low profile the tire is, I would not need to use foam inserts? What was recommended back in the day? Or were they not using inserts back then?
aconsola
Post by aconsola »
I don't think any of the 2.0 tires used inserts.
Motor'n
Post by Motor'n »
Most of the tires in the early days did not use foams. they came later when the tracks started to go hard pack and clay.
Racin since 1987
m2fit4u2
Post by m2fit4u2 »
Ok, thank you for the replys :D
Return to “Losi Forum”
