Period tyres for running
Are there any tyres still available in either 2.0 or the smaller size?
I dont want new 2.2 as its only for running round the garden and I prefer the look of the smaller sizes.
Thanks
Thanks
Still building my RC10
Re: Period tyres for running
good lookin out, thx tulsa!
- aeiou
Here's another 2.0" rear option:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=LOSA7378S
I use these on my Team Car runner.
Sub-2.0":
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLDX8&P=0
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLDW6&P=0
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLDX7&P=0
Brat tires: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRCW6&P=ML
The front wheels will fit the RC10 axles with HPI bearing adapters, and the rear tires should fit some mini-size touring car wheels, which will fit with HPI 12mm hex adapters.
- flipwils11
- Been thanked: 19 times
Got these and I'm having a bitch of a time getting the 2.1's to stay on. I tried gluing them but I must be doing something wrong. Do you just just run glue on the inner rim of the wheel and get the tire lip to adhere (hopefully)? Mine didn't stay put and they're loose on the wheel causing them to peel off when driving. I put the 2.0 Tamiya spikes on instead which were a much tighter fit so hopefully they don't need glue.tulsa wrote:here you go. 2.0" http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGD99&P=7
2.1" http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ70&P=7
- badattitude
"I put the 2.0 Tamiya spikes on instead which were a much tighter fit so hopefully they don't need glue."
They don't need glue. I'm using these Tamiya tires on my CE with 3 piece rims. They are working great. Only tip is to pinch the sidewall in and leave the rim on the outside. I could not get the rim to fit all the way into the outer mounting groove on the tire. Hope that makes sense...it works on the three piece rims at least.
- 997 Views
Last post by DerbyDan
- 1394 Views
Last post by marlo
- 2999 Views
Last post by V12
- 2281 Views
- 1867 Views
Last post by kenooze
- 2151 Views
Last post by vintageguy
- 812 Views
- 1382 Views
Last post by minichamps11
